Hubnut
My impact wrench, Chinese-made (crap), stopped working. All it does is let air pass through with no rotation. Both F and R positions are the same. Does this mean this thing is Tacoed?
It just so happens I make the IR products for a living...
1) oil is an impact/air tools best friend (an inline oiler is highly recommended but if you don't have one, make sure to put oil in it every time you use it - like five drops or so)
2) water is an air tool's worse enemy - an inline water separator is recommended as well, they're cheap compared to having to replace a tool
3) when you bang the anvil on a hard bench (the square end) you're actually forcing the air motor away from the endplate. These motors are made to 'float' so if you're having to force the motor away from the endplate to get it going again - you aren't oiling it enough.
4) the mechanism portion under the nose piece (hammer case) is sealed from the motor and uses grease, there should be a grease fitting either on the hammer case itself or one on the rear of the housing that forces grease up through the anvil and into the nose section. You should grease them as prescribed with the maintenance literature, some tools you can get away with over greasing (it blows out the excess) while others will 'gunk up' and become sluggish.
5) I don't recommend putting any kind of detergent in the tool to clean it out, the vanes are either phenolic or a nylon material. In either case, an oil stripping detergent will decrease the life of the vanes. If the tool is sluggish, flush it with the recommended oil - you can not over oil these motors! The only thing you'll do is make a mess with the excess oil blowing out of the exhaust.
6) don't be afraid to take apart your impact, they are very simple in design and easy to reassemble. However, if you have an aluminum or composite tool - make sure to evenly torque the nose piece (hammer case) back on. This is especially crucial for the aluminum models, it's simple, just lightly torque each screw prior to your final torque (we use a multi-spindle set-up that torques them evenly at the same time during assembly).
In my shop right now I have two CP 1/2" drive and no grease fittings, two CP 3/4" drives and no grease fittings, one IR 3/4" and again no grease fittings, and one IR spline drive with no grease fittings.
I guess I just have bad luck and bought impacts shorted on parts.
