efilnikufecin
i have a 90 burb 350 tbi.i removed the stock fuel tank and pump.i'm have a fuel cell that i'm going to run.i got a inline walbro pump form howell for a tbi setup.problem is i was going to use the stock wires going to factory fuel pump for my power and ground to the new walbro,but they don't seem to have the power to run it.i tested the pump on the battery and it will fire right up.i tested the factory lines with a light tester,it will light up but i dont have a meter to check voltage.so can i run a hot wire off the ignition to power the new pump?or how can i go about getting this pump powered?thanks
