infrared temp gun
76zimmer
Flyin Rat
Staff member
Moderator
Kzoo, Mi
Anybody have one of these, I got one a few weeks ago, and the uses are endless.
Oh yeah ... cooking gears, annoying cats, it goes on and on...
and occasionally checking radiator hoses =))
-- A
we had a bad skip in a toyota v6. found dead cyl with it. and found bad plug on injector wire in under 2 min. cold exaust port found it.
found a bad half a carb that needed a reman as 1 side of exaust was cold on outer ports and other was cold on inner ports. split port intake works this way. so carb was bad. and man thay do work great. i even use it to check tstats for open and close temps or for pluged heater cores.
invaluable in the marine biz, a must have... I've had one for about 5 yrs now...
Other uses??...
Can I use it too tell which chick at the bar is the "hottest??"....:wink1:
It would save a lot of time and money,if I knew which one was "warm for my form",if you catch my drift....:p:
I just take one off the engine and use it when i'm up the the FD.
