SchnorrCS
I kept MOST of mine. I did a HUGE cut on the fronts, and I cut high enough that I could pinch the inner skin of te fender it self to the outside, and layed a bead on the whole edge, which really strenghthened the fender. I could almost jack the truck up by them, that strong. Then for the inner, I had to cut a ton off the back, but no big deal. I was more worried about the top and front cause that's where most road grime and crap could hit anything that matters, so I used a propane torch to take some of the timber out of the metal, beat the sh!t out of it with my BFH and welded/bolted it back up. I'm not as into looks as some of the pictures on here, it definatly doesn't look stock, but it doesn't look terrible either. I'm now running 36 inch swampers with a 2 inch lift, and I hit bump stops before anything rubs. This pic is when I was running 34x10.5 15s with no lift at all.
Thanks for the insight!
