OK so I searched and search and can't find any information on why or why not to do this or even if it is possable.
THE IDEA
Despite reasoning, I wanted to know if you could use the concept of air bags for body mounts/lift. The idea would be so while your on the street you could ride low for handling ect. and then increase your lift lets say 2-3" when you wheel. I don't care if you thinks its dumb, pointless or a waist of money all i'm looking for is constructive feedback or ideas. So if you don't like it then don't post.
I have no experience with air bags or body lifts so im kind of in the dark. However every thing i can think of that is required for a body lift can be adjusted to accommodate this idea its weather an air bags can handle this task and still act as a body mount at the same time. I do know that range rover has something similar to this idea as i have driven one and this is where i got the idea. So if you have good information or creative ideas post them up or even a place to get information.
TRUCK INFO
My truck is not my daily but it dose see a lot of road time and i try to make it as universal as possible. I have built it form stock myself and have pretty good skills or have buddies that have better. My truck has 6" of lift with 39.5" tires and trimed wells that only rub sometimes when i wheel here hard. 4" front spring with longer shackles and zero rate. Shackle flip and 2" spring in the rear. let me know if you need more info.
THE IDEA
TRUCK INFO
