After buying a 14 bolt semi float I finally decided on tires.
35x11.5x17
Fallen wild peak.
I did 4.56 gears and was back and fourth on 33s or 35s
I really didn’t want to lift the jimmy but I figured the 35s will look better. I took out the helper spring in the rear. Added a zero rate 1” block.
About to remove the front and rebuild. I’m curious on the minimum lift it will need for 35s?
35x11.5x17
Fallen wild peak.
