lectric80
3/4 ton status
Since I have never used one, I am not certain, but I believe that it uses a switch to signal the relay to combine the batteries. This means during the months that you don't need the boost, you can leave the switch off, but when you need it, a quick flip of a switch will activate the feature. Not sure on the setup though, since I have never done those setups before.
It could be setup to just receive a signal when you turn the key, or you could setup a switch to send a power signal to activate the combine. That is the way I understand them.
The OP was concerned with his vehicle starting when it is -30 or more out, a $23 block heater is a very wise investment even with dual batteries IMO.
