installing lift ?'s
wahbob
Austin,Texas
installing lift ?\'s
I am installing my 4" rough country lift. Springs in front and blocks in the back(i know, i know). Anyway when some of you were installing your front springs did you have to remove the brake lines to install them? My axle doesnt seem to be down far enough for me to put the new ones on, the only way i see is to disconnect the lines because they are at their limit. If so how the hell do seperate it from the frame???? I took the clip off of the frontside of the frame---now what.?.??
Thanks in advance,
Mike B.
Re: installing lift ?\'s
remove the callipers. not the lines. this way you dont have to bleed them again.
grant
Remove the calipers, but after the install, make sure that you have enough slack in your lines at full droop. If not, you may have to route them under the frame instead of through.
I'm not suggesting removing the lines to install the lift. I am saying that you need to check them at full droop. If they are tight, you need to address that issue.
