interior side panel template
Aluminum Diamond
Aluminum Diamond plate is what i am about to use for these side panels. I think the industrial look will work well in the back and not cause any issues. I will post some pics of the install after. i plan on using some rubber stoppers or carpet squares so that it will not squeak or grind against the mounting brackets. Does anyone have any other creative ideas?
Fantastic! Who knew finding rear panels would be so difficult. One more item off the check list! Thank you!
I did mine out of diamond plate. Was quite the process to print them out and then get them cut. But they turned out great.
Here is a link for those of you that are having a hard time. I just placed an order with the local steel place. I did not make any changes to these templates, I did however make them into DXF files for the local metal shop. They CNC plasma cut and it should turn out nice.
@Holey76
The google drive link right above your post in post #33 has the panels you can download them from the google drive link.
How do
How do you convert the file(s)
@Holey76 there's 2 sets of files, one pdf and one dxf. if you're going to have them cut by somebody with a cnc they'll more than likely need the dxf. The PDF files you can take down to a print shop and have them printed full size
