nitro_rat
Cost to cover a bench seat locally was $150 10 years ago here. Probably much more now. That was including whatever material the shop had on hand.
To match the fabric on those front buckets will require nos factory material to be ordered. Last time I did that, the material was something like $300 a yard. Add that to the regular cost.
Quite possibly cheaper to buy a different donor.
As to swapping in the suburban rear seat...
The floor structure is completely different. Not saying it's not possible, but I don't think it would work well at all. Even if you cut out the floor and ditched the saddle tanks, just look for pics of a burb with the rear section of the roof cut off. There is like half an extended cab area behind the back door on the ones that get closed back in. If you put the seat in a crew, I don't think the back seat passengers would have much leg room.
If you ditched the brackets under the seat bottom and just set the seats in there, I think the seat would also be much higher tahn the correct one. Kind of like theater seating...but not enough head or leg room for an adult.
Maybe small kids would think it was cool...
