Hey guys, just recently finished a lift on my K5... Or so I thought...
Lifted it 3" with 4" of total lift in the rear(2.5 ORD shackle flip, super shackles, zero rates). Also had my stock driveshaft lengthened within 1 - 1.5" of slip yoke showing. Had also shimmed my rear end and got really good angles which are really close to each other. EVERYTHING SHOULD BE RIGHT.
BUT, for whatever reason when coasting, I get a grinding noise. Under load, everything is fine. Had it up to 75 and it was smooth as a bird. until you put it in neutral and/or let off the gas and there is no load on the shaft. Then it makes the grinding noise.
What gives? This is not a huge lift. Just big enough to clear 33's. And I know that a cv shaft or slip yoke eliminator is more than likely the golden ticket, but I've dropped thousands into this thing recently and quite honestly can't afford to keep this trend going. I just want to drive and enjoy my truck. Any help or input is appreciated!
Thanks guys!
Thanks guys!
