Checking intrest for soft tops for K5's. Getting quotes for material, tubing for Bows, bracketry, packaging and what not. Trying to find out if its worth the venture. It will be a replica of a STC top basically except heavier duty Bows, better mounting brackets. Possibly two options for mounting brackets, Nylon plastic, for a cost savings and Stainless Steel mounting hardware would be a bit more ofcourse. If I can improve on their design I will.
Also as far as material, I got a quote for the same factory material as a Jeep Rubicon uses. Yea, or ney on this material? I think its tough material, It works on Jeeps. I have priced tubing for the Bows aswell. Specialty Top Company used 3/4 EMT Tube. I will to use 1" tube so its a little more stiff to wind buffeting. Cost has yet to be determined. Still need more info. This is very early in the getting off the ground stage, I need and want openions. Post up please.
