SoCalBikerDude
Newbie
Planning a project.
I'm Tim from Yucaipa, California.
I've got a 1984 32' GMC Midas RV Class A.
It was hit in the front right corner before I got it and it wracked the coach so hard that the roof joints at all 4 walls leak and the walls near the front are separated from the floor.
My plan is to strip it to the chassis which is a 2-and-a-half ton GMC with a 454CI and a TH400, and build up a custom double-taker.
Among the possible concepts is to set a Suburban body on it with a Dually pickup bed behind it, delete the rear fender wells in the body/cab and essentially build a super long pickup. Also thinking of 4-linking the rear end, C-notching the frame, and bagging all 4 corners. so I can lay frame for easy loading of the bike, toolbox, or whatever.
My plan is to strip it to the chassis which is a 2-and-a-half ton GMC with a 454CI and a TH400, and build up a custom double-taker.Among the possible concepts is to set a Suburban body on it with a Dually pickup bed behind it, delete the rear fender wells in the body/cab and essentially build a super long pickup. Also thinking of 4-linking the rear end, C-notching the frame, and bagging all 4 corners. so I can lay frame for easy loading of the bike, toolbox, or whatever.
Two kids, 5 and 6. Currently and for the first time unemployed, loving my 'time off' but come February 9th should be back working again for General Dymanics, 6 month contract stateside, then a year deployed to.. you guessed it; Afghanistan! But as a civillian, with civillian pay.
Was headed to WyoTech for their Street Rod and Custom Fabrication with Collision Repair/Refinishing, but it got pushed back till May, that's too long w/o a job or a crap job inbetween so I decided to do this contract for a year, then goto school. So when I get back, I'll be heading to Laramie WY, or Blairsville PA.
