Welcome @hambone933
Congrats on your new purchase, sound like a great starting point
Just joined i have a 1983 c10 that I swapted in a 5.9 cummins w/a sm465 trans turned up to 300 hp and 700 lb foot runs really good has been in the truck since 1990 I was pulling a 26 ft aljoe trailer back then there was not a clutch to hold the torque it put out I just go a clutch from south bend clutch hopefully it will hold
Hey I'm Eddie, I'm from Georgia. I have a 1987 Chevy K5 blazer. I'm glad to join the group.Welcome to CK5, stop in and say hello, this is a great place to make your first post and tell us a little about yourself/truck.![]()
Hi Eddie, welcome aboard.Hey I'm Eddie, I'm from Georgia. I have a 1987 Chevy K5 blazer. I'm glad to join the group.
I got a 1987 K5 that I inherited from my late dad. I've had it since 2019. Several months ago I dropped the drive shaft and cracked the transfer case back case and tail housing, since then I have replaced the back case and fixed the tail housing , but when I try to slide the slip yoke in, it is a very tight fit. I have to tap the slip yoke in. Just wondering what cHi Eddie from Georgia
welcome aboard, peruse around and let us know how we can help
Not a new seal or bushing. Just have to tap it in.Really tight new seal?
Can you tap it in, Or, Do you have to get a BFH and give it what for? Cuz, there's a difference. The prior is probably OK, the latter, not so much.
With a rubber hammer.Not a new seal or bushing. Just have to tap it in.
Can cause it.I got a 1987 K5 that I inherited from my late dad. I've had it since 2019. Several months ago I dropped the drive shaft and cracked the transfer case back case and tail housing, since then I have replaced the back case and fixed the tail housing , but when I try to slide the slip yoke in, it is a very tight fit. I have to tap the slip yoke in. Just wondering what c
Will it Break in over time?Probably OK
It is a different slip yoke.We are all will to sort this with but you start a thread in the garage for this discussion.
Thinking maybe the slip yoke got tweaked when t case broke.
Welcome to CK5 @Eddie's K5
When I drop the driveshaft while driving. It must have bent the output shaft on the transfer case.Really tight new seal?
Could be, hopefully not, but maybe it has one spline groove slightly damaged?When I drop the driveshaft while driving. It must have bent the output shaft on the transfer case.
Done took a file to them and made sure they were smooth.Could be, hopefully not, but maybe it has one spline groove slightly damaged?
