Inventory Reduction on bunches of parts in stock, check out details inside!
----- 2nd List of items -----
Racing Power Company : www.racingpowercompany.com (pulleys)
R9604 – SB Chevy, single groove WP Pulley, LWP Upper
R9607 - SB Chevy, double groove WP Pulley, LWP Lower
R5606 – 14” Billet Steering Wheel w/ leather grip
R6168 – Polished Alum. Flame Interior Mirror
R6166 – Polished Alum. Flame Interior Mirror
R8963 – SB Chevy, Triple Groove, SWP Lower
R5602C – Chrome Aluminum GM 67-94 Steering Adapter
R5600C - Chrome Aluminum GM 67-94 Horn Button – Plain
R9817 – Chrome SB/BB Single Groove Add-On Crank Pulley – LWP
R9603 – Chrome SB Double Groove Crank Pulley – SWP
R9600 – Chrome SB Single Groove WP Pulley – SWP
R6086 – Chrome Hose/wire line clamps – ¼” (4 Pack)
R6085 - Chrome Hose/wire line clamps – 3/16” (4 Pack)
R6087 - Chrome Hose/wire line clamps – 5/16” (4 Pack)
R4960 – Chrome Chevy SB Timing Tab 6-8” Balancer
R6041 – Polished Alum. Chevy SB Timing Tab
R2183 – Chrome Knurled Air Cleaner Nut w/ ¼-20 Thread
R9601 – Chrome SB Chevy Double Groove WP Pulley – SWP
R6019 – Black Aluminum T-Bar 4-5/8 tall with ¼-20x1-1/4 Stub 4pack
R9120 – Chome T-Bar 4-1/4 w/ ¼-20 x 1-3/8” Stub 4pack
R9486 – Satin Alum. Triple Groove Crank Pulley – LWP
R6008 – Polished Billet PCV Valve w/ 3/4 “ Neck
R6050 – Polished Alum. Push-in Oil Cap – 1” Neck
R6000 – Polished Alum. PCV Push-in Breather – 1” Neck
R9479 – Satin Alum. Chevy SB Double Groove WP Pulley – SWP
R9787 – Chrome Push-In Oil Cap w/ Oil Logo
R4994 – Chrome GM T350 Trans Dipstick – 34” Long
R9481 – Satin Alum. SB Double Groove Crankshaft Pulley – SWP
R8858 – Satin Alum. SB Triple Groove Pulley – SWP
R9483 – Satin Alum. SB Double Groove WP Pulley – LWP
R9481 – Satin Alum. SB Double Groove Crank Pully – SWP
R9421 – Chrome GM T350 Trans Dipstick and Tube – 27” Long
R4957 – Chrome 55-79 SB Chevy Dipstick and Tube
R9482 – Satin Alum. SB Single Groove WP Pulley – LWP
R9478 – Satin Alum. SB Single Groove WP Pulley – SWP
R9480 – Satin Alum. SB Single Groove Crank Pulley – SWP
R9487 – Satin Alum. SB Single Groove Alternator Pulley
R8847 – Satin Alum. Early GM Double Groove Power Steering Pulley
R9453 – Chrome Fan Shroud – 3” Wide x 20” Diameter
R7304 – Chrome 24” Stainless Radiator Hose Kit w/ Polished Caps
R6063 – Billet Alum. GM Shifter
R6073X – Stainless 2” x 15” Overflow Tank w/ Mounting Bracket
R6002 – Polished Alum. SB O-ring Water Neck – Straight UP
R6015 – Polished Alum. 66-75 SB O-Ring Water Neck – 15 Deg.
R6003 – Polished Alum. SB O-ring Water neck – 40 Deg.
R6009 – Polished Alum. Chevy O-Ring Water Neck – 90 Deg.
R6039 – Polished Alum. 2 Piece Wire Loom w/ Bracket
R9530 – Chrome Ford C-4 Trans Pan – Finned
R9122 – Chrome Turbo 350 Trans Pan – Finned
R8491 – Polished Alum. T350 Trans Pan – Finned w/ gasket
R4786 – Chrome Chevy Diff Cover w/o Plug – 10 Bolt
R9588 – Chrome T350 & 400 Flywheel – 2-7/8” Starter Slot
R9005 – Chrome 55-79 SB Oil Pan – Driver Side Dipstick
Allstar Performance : www.allstarperformance.com
10500 - Fire Extinguisher 2.5lb Red
Proform Performance Parts : www.proformparts.com
141-800 – Fabricated Aluminum Valve Cover – SB Chevy
141-103 – Stamped Valve Cover – Tall SB Chevy
141-751 – Black Crinkle Tall Cover – SB Chevy
141-302- Chevy 14” Classic Air Cleaner Kit w/ Bowtie Center Nut
141-752 –14” Black Crinkle Air Cleaner Kit w/ Bowtie Center Nut
141-630 – Chevy Push-In Oil Filler Cap
141-616 – Chevy Bowtie Push-In Air Breather Cap, 3” Diameter
141-210 – Fuel Pump Block Off Plate – SB Chevy
Motive Gear : www.motivegear.com
G875456 – Ring and Pinion 4.56:1 Ratio, GM 7.5 in Rearend
All these products and no hits! Come on now, we have lots of chevy stuff to get rid of and great pricing.
We will be closed from January 17th until January the 26th. We will be in Laughlin,NV racing our Stock Full Dodge and Class 8 Chevy in the Laughlin Desert Challenge. We will return Monday the 26th and be accepting orders.
Thanks, Jereme @ RPM
When we return I will post up prices for you that don't like to type :)
All prices shipped!
Taylor Wires : www.taylorvertex.com
98003 - T-Volt GM LS1 Custom Fit Black - $72
76230 - Chevy V8 Race Fit – Red - $54
74202 - Chevy V8 90 Deg. HEI Red - $52
74658 - Ford SB V8 5.0L – Blue - $52
73251 - Spiro Pro Red 90 degree - $59
48101 - Taylor Aluminum Battery Box - $142
1036 – Battery Disconnect Kit - $37
MSD Ignition : www.msdignition.com
5553 - Universal V8 - 90 Deg – $39.20
5541 - Ford 302/351W HEI/Straight - $34
5565 - Chevy Small Block – Socket - $34
5554 - Chevy Small Block HEI/90 deg. - $34
5551 - Universal V8 – Straight - $38
31189 – Super Conductor Wire Set, Multi-Angle Plug, HEI - $76
3414 - 8.5MM Wire Cylinder Marker - $10.59
35599 - Super Conductor Plug Wire Set, SB Chevy w/ HEI Cap - $76
34069 - Replacement Super Cond. Plug Wire - $19
8860 – Cable Assembly , 2 Wire - $15
8950 - RPM Activated Switch - $80
8471 - Bronze Dist. Gear .500" - $42
6420 - Hi Performance w/ Rev Control Box - $202
8202 - Blaster 2 Coil - $39
Mr. Gasket : www.mr-gasket.com
5881 - O/P GSKT SB CHEV 75-79 - $18
196 - OIL PAN GSKT SB CHEV - $15
6026 - Carburetor Bushing Kit - $10
6002 - CRANKCASE EVACUATION SYSTEM - $44
1617 - 24" Competition-Style Lanyard Cables w/torsion clips - $20
2043 - ALUMINUM VENT BREATHER-3/8" TUBE - $20
9871 - HEATER HOSE BRACKET-CHROME - $11
93 - TIMING Cover Gasket Kit-SBC - $11
90 - Timing Cover gasket, Stock Cover 265-400 Chevy - $12
5820 - Intake GSKT SB Chevy - $20
1616 - HOOD PIN KIT-TORSION CLIP-1/2 - $16
175 - VLV CVR GSKT SB CHEV 55-85 - $15
1961 - REAR MAIN SEAL SB CHEV (S-LIP) - $15
1960 - REAR MAIN SEAL SB CHEV (D-LIP) - $15
18 - Timing Cover Seal Small Block Chevy - $12
738G - Water Outlet Gasket-Chevy - $16
9790 - COMPETITION AIR CLEANER 14" - $26
6007 – 2” CARBURETOR SPACER-OPEN CENTER - $34
8091 - FLEX-BRAID HOSE SLEEVING KIT-BLUE - $27
8090 - FLEX-BRAID HOSE SLEEVING KIT-RED - $27
SCE Gasket : www.scegasketsonline.com
4011 - PRO COPPER Exh. SBC 1.5" to 1.625" Round Primary Tube - $35
LAST LIST OF THE INVENTORY WE ARE REDUCING FOR NOW!
Hitachi : www.hitachi-hap.com
PP106 – Hi-Torque Chevy SB/BB Starter 153/168 tooth - $160
Powermaster : www.powermastermotorsports.com
9600 - Chevy 153 or 168 Tooth Flywheel - $179 – SOLD!!
Crane Cams : www.cranecams.com
11745-16 – Energizer Rocker Arms - 1.5 ratio with 7/16 studs - $190
Holley Carb Products : www.holley.com
8004 – Weiand Chevy SB Intake Manifold - $140
0-80670 – Street Avenger Carb. 670CFM - $370
12-802-1 – Holley Blue Fuel Pump - $130
37-1544 – Holley Rebuild kit for 4150 Carbs - $35
37-1542 – Holley Rebuild kit for 4160 Carbs - $26
37-1543 – Holley Rebuild kit for 2300 Carbs - $24
37-1546 – Holley Rebuild kit for 4150 HP Carbs - $46
37-1547 – Holley Rebuild kit for 4500 Carbs - $55
20-13 – Secondary Springs - $17
20-64 – Throttle/Cruise Control Stud - $19
20-2 – Studs - $15
Barry Grant : www.barrygrant.com
170025 - 2-Port PLUS+ Pressure Regulator - $109
170002 – 280GPH Fuel Pump - $290
Lokar Performance : www.lokar.com
TC-1000U – 24” Cable Black Throttle Kits - $39
TD-3350400FM – TH350/TH400 Firewall Mount Dipstick - $79
TD-30C4FMPAN – Ford C4 Firewall Mount Dipstick - $110
TD-3350TM – Aluminum Trans Dipstick TH350 - $72
ED-5001 – Chevy SB (80 & UP) Aluminum Oil Dipstick - $56
ED-5002 – Chevy SB (80 & Down) Aluminum Oil Dipstick - $54
Trans Dapt : www.tdperformance.com
1088 – 55-79 Chevy SB Econo Oil Pan - $192
Milodon : www.milodon.com
30700 – 55-79 Chevy SB Stock Oil Pan - $97
Meziere : www.meziere.com
WP101S – Chevy SB Electric WP – Black - $290
WP1150S – 1.5” Radiator Hose to 1” – Black - $24
B&M Shifters : www.bmracing.com
80659 – Chrome Alum. Knob with Button - $42
80605 – 5 Ft. Universal Shifter Cable - $42
70266 – Racing Transmission Cooler 11”x8”X1.5” - $76
80690 – B&M MegaShifter - $210
Hurst Shifters : www.hurst-shifters.com
1534813 – Brush Alum. Shifter 3/8-16 Thread - $28
5000025 – 5ft. Cable Fits Hurst Shifters - $48
3160001 – Quarter Stick Shifter - $185
Edelbrock : www.edelbrock.com
2101 – Performer Intake Manifold NON-EGR - $132
Flex-a-lite : www.flex-a-lite.com
3816 – Trans Cooler 7.5” x 12” x ¾” - $35
Professional Products : www.professional-products.com
52031 – Intake Manifold 57-95 SB Chevy for 23Deg. Heads - $149
ARP Bolts : www.arp-bolts.com
230-7001 – Oil Pump Studs SB Chevy - $12
134-2501 – Harmonic Damper Bolts SB Chevy - $25
100-2801 – Flywheel bolts Chevy/Ford 7/16” x 1” - $14
100-2901 - Flywheel bolts Chevy/Ford 7/16” x .68” - $14
230-7301 – Torque Convertor Bolts T350 or T400 3/8”-24 - $17
430-7402 – Chevy SB Stainless Thermostat Housing Bolts - $12
430-3202 – Chevy SB Stainless Waterpump Bolts - $24
430-1602 – Chevy SB Stainless Fuel Pump Bolts - $12
400-1502 – Chevy SB Stainless timing and Waterpump bolts - $20
400-1101 – Chevy SB Stainless Header Bolt Kit – 3/8” x .750 - $24
434-2001 – Chevy SB Stainless Intake Manifold bolts - $32
534-9601 – Chevy SB Stainless Head Fastener Kit - $99
Gforce : www.gforce.com
WM2 – Window Latch Kit w/ Round Bar - $30
6000BK – Latch & Link 5-point Harness / Black - $74
Moroso : www.moroso.com
71900 – Spark Plug Indexing Washers - $20
TCI : www.tciauto.com
518050 – Ford C4 Pan fill converion kit - $18
