----- 2nd List of items -----
Racing Power Company :
www.racingpowercompany.com (pulleys)
R9604 – SB Chevy, single groove WP Pulley, LWP Upper
R9607 - SB Chevy, double groove WP Pulley, LWP Lower
R5606 – 14” Billet Steering Wheel w/ leather grip
R6168 – Polished Alum. Flame Interior Mirror
R6166 – Polished Alum. Flame Interior Mirror
R8963 – SB Chevy, Triple Groove, SWP Lower
R5602C – Chrome Aluminum GM 67-94 Steering Adapter
R5600C - Chrome Aluminum GM 67-94 Horn Button – Plain
R9817 – Chrome SB/BB Single Groove Add-On Crank Pulley – LWP
R9603 – Chrome SB Double Groove Crank Pulley – SWP
R9600 – Chrome SB Single Groove WP Pulley – SWP
R6086 – Chrome Hose/wire line clamps – ¼” (4 Pack)
R6085 - Chrome Hose/wire line clamps – 3/16” (4 Pack)
R6087 - Chrome Hose/wire line clamps – 5/16” (4 Pack)
R4960 – Chrome Chevy SB Timing Tab 6-8” Balancer
R6041 – Polished Alum. Chevy SB Timing Tab
R2183 – Chrome Knurled Air Cleaner Nut w/ ¼-20 Thread
R9601 – Chrome SB Chevy Double Groove WP Pulley – SWP
R6019 – Black Aluminum T-Bar 4-5/8 tall with ¼-20x1-1/4 Stub 4pack
R9120 – Chome T-Bar 4-1/4 w/ ¼-20 x 1-3/8” Stub 4pack
R9486 – Satin Alum. Triple Groove Crank Pulley – LWP
R6008 – Polished Billet PCV Valve w/ 3/4 “ Neck
R6050 – Polished Alum. Push-in Oil Cap – 1” Neck
R6000 – Polished Alum. PCV Push-in Breather – 1” Neck
R9479 – Satin Alum. Chevy SB Double Groove WP Pulley – SWP
R9787 – Chrome Push-In Oil Cap w/ Oil Logo
R4994 – Chrome GM T350 Trans Dipstick – 34” Long
R9481 – Satin Alum. SB Double Groove Crankshaft Pulley – SWP
R8858 – Satin Alum. SB Triple Groove Pulley – SWP
R9483 – Satin Alum. SB Double Groove WP Pulley – LWP
R9481 – Satin Alum. SB Double Groove Crank Pully – SWP
R9421 – Chrome GM T350 Trans Dipstick and Tube – 27” Long
R4957 – Chrome 55-79 SB Chevy Dipstick and Tube
R9482 – Satin Alum. SB Single Groove WP Pulley – LWP
R9478 – Satin Alum. SB Single Groove WP Pulley – SWP
R9480 – Satin Alum. SB Single Groove Crank Pulley – SWP
R9487 – Satin Alum. SB Single Groove Alternator Pulley
R8847 – Satin Alum. Early GM Double Groove Power Steering Pulley
R9453 – Chrome Fan Shroud – 3” Wide x 20” Diameter
R7304 – Chrome 24” Stainless Radiator Hose Kit w/ Polished Caps
R6063 – Billet Alum. GM Shifter
R6073X – Stainless 2” x 15” Overflow Tank w/ Mounting Bracket
R6002 – Polished Alum. SB O-ring Water Neck – Straight UP
R6015 – Polished Alum. 66-75 SB O-Ring Water Neck – 15 Deg.
R6003 – Polished Alum. SB O-ring Water neck – 40 Deg.
R6009 – Polished Alum. Chevy O-Ring Water Neck – 90 Deg.
R6039 – Polished Alum. 2 Piece Wire Loom w/ Bracket
R9530 – Chrome Ford C-4 Trans Pan – Finned
R9122 – Chrome Turbo 350 Trans Pan – Finned
R8491 – Polished Alum. T350 Trans Pan – Finned w/ gasket
R4786 – Chrome Chevy Diff Cover w/o Plug – 10 Bolt
R9588 – Chrome T350 & 400 Flywheel – 2-7/8” Starter Slot
R9005 – Chrome 55-79 SB Oil Pan – Driver Side Dipstick
Allstar Performance :
www.allstarperformance.com
10500 - Fire Extinguisher 2.5lb Red
Proform Performance Parts :
www.proformparts.com
141-800 – Fabricated Aluminum Valve Cover – SB Chevy
141-103 – Stamped Valve Cover – Tall SB Chevy
141-751 – Black Crinkle Tall Cover – SB Chevy
141-302- Chevy 14” Classic Air Cleaner Kit w/ Bowtie Center Nut
141-752 –14” Black Crinkle Air Cleaner Kit w/ Bowtie Center Nut
141-630 – Chevy Push-In Oil Filler Cap
141-616 – Chevy Bowtie Push-In Air Breather Cap, 3” Diameter
141-210 – Fuel Pump Block Off Plate – SB Chevy
Motive Gear :
www.motivegear.com
G875456 – Ring and Pinion 4.56:1 Ratio, GM 7.5 in Rearend
