Is there a difference in 1/2 ton and 3/4 ton rear springs?
I've got a set of bags on my tow /dd and there great can air up or down for whatever I'm towing and ride stays the same
My problem is finding a kit that will work with my set up. My Burb has 1tons and 3" of lift. I'm assuming the kits are designed for stock axle tubes and stock lift height. Anybody know how I can get a kit that will work?
if you don't have lift springs you will be just fine.
the kit I listed is for our vintage trucks and it needs 4 bolts to the frame and then sets on top of the leaf spring ubolt plate .
but even if you did have lift springs its just a simple spacer and longer bolt to fill the gap .
looks like suburbans get a 2100 kit . http://www.summitracing.com/parts/fip-2100/overview/
cheeper price http://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=4432
here is the install directions. http://static.summitracing.com/global/images/instructions/fip-rrin2100.pdf
Thanks sweetk30! Great info. It looks like the brackets are attached to the spring pack instead of the axle tubes. That looks like it will work then. The other kits I was looking at had the brackets around the axle tube, which wouldnt have worked in my case. Thanks again.:waytogo:
Great price at SDtrucksprings with the Sale30 code. Total comes out to $289.19:eek1:
