Is there any difference in the cab between a 78 and 89 K5 cab?
I believe the floor behind the front seats is a different height.
One is older than the other, I believe...........
Hey, what do I know? I run Fords....
But you weren't getting many replies, figured I'd up the count a little. Besides I like your fallguy avatar.
little things
nothing that would stop a swap
I have an 85 cab on my 78 chassis
with 78 front clip
I had a '77 GMC that the previous owner swapped a '85 cab onto it ,it was a 2wd cab and the truck was a 4x4 so the floor tunnel had to be modified to allow a NP-205 to be installed (I put that in it,it had a NP-203 when I bought it)...
I recall the rear cab mount bushings being taller than the ones on another mid 70's 4x4 I had that was all original..other than that it was a bolt on deal..
yeah think so
I put some 91 seats in
couple holes lined up but not all
