Is there such a thing as a fast shifting truck manual transmission? Or how about one with some closer ratios than the SM465?
Advance sells a fair number of adapters.
As far as I'm concerned, there aren't any car manual transmissions out there that will reliably handle the stresses a full size truck will inflict on them, not to mention fitment (shifter placement), and issues with mating them up to a t-case in 4WD apps.
Get a full manual TH400 and a ratchet shifter for the floor. If you want you could leave the clutch pedal in the truck and push it everytime you bump a gear just for old times sake.
good advice. I once had a 4spd truck I swapped an auto in and left the clutch pedal. Goin down a curvy road I would start bouncing the clutch pedal off the floor "ahhhh no brakes" Got many passengers to turn ghost white.As far as "short throw" shifters for the sm465 that doesnt exist. Cutting the stick doesnt make the trans shift any different or any shorter, you just cut the stick, thats it....
From what I've heard the NV4500 has the same gear spacing as the 465 but with overdrive. The NV3500 has tighter spacing and would work, but I'm not sure it'd hold up to the power/weight. Get a full manual TH400 and a ratchet shifter for the floor. If you want you could leave the clutch pedal in the truck and push it everytime you bump a gear just for old times sake.
