Is this a 12 bolt ??? Pic
pornorob
;jkl;
:confused: So is this a 12 bolt ??.....if it is what is the part number for the ujoint that connects the diff and the drive shaft thanx guys :confused:
Chip away some of that rust so we can see it better to make sure,,, :D
J/K looks like it to me also :waytogo:
BTW, that is a REALLY cool loopy brake line there,,,kinda gives the brake fluid a ride there eh? :p:
thanx guys ... that could be why the stock rear u joint that I bought for it won't fit :D
It will increase velocity, making the brakes operate better.
You probably need a conversion joint.
Brake fluid cooler!
The "loop" is actully a brake fluid cooler!..I do that all the time rather than cut and re-flare a new line..ya,I'm a lazy F***! when it comes to double flaring brake lines!
Anyone else notice all the "pre made" brake lines are either 4" too short,or a foot too long every time you go to use one??..must have taken them 20 years to figure out just the wrong length for 90% of all vehicles,huh?... :rolleyes: --I just buy the longer ones and "loop" em now.. :crazy: ..
