well i got the eddy intake and carb and accel hei distributor from my 305 and i supposedly have corvette heads too. my plan was to pull these parts off my 305 and put them towards my 400 build up. start with a 400 2 bolt block, deck it, align hone it, magnaflux the crank and rods, shot peen the rods, balance the rotating assembly together, shave the heads, 5 angle valve job on the heads, stock crank, rods, speed pro pistons and piston rings, melling hv oil pump, stock pickup and pan, 2 piece timing cover, stock balancer, stock front drive system, comp cams 4x4 cam kit, flowtech afterburner headers, manley pushrods, comp cams pro magnum roller rockers (don't know what ratio), manley valves, manley valve springs or crane cams beehive valve springs, clevite 77 bearings, arp hex head black oxide fasteners, felpro or cometic gaskets, paint it and put glyptal in the lifter valley and wherever else its supposed to go, undecided on valve covers and other dress up items
