Is this a good deal on a rear end for a K5??Would it even work??
blbikerood
Registered Member
Missouri
out of a 94 model heavy half , meaning 3/4 ton 14 bolt rear end with 6 hole axles, 373 gear with posi ,550.00 ,
Some would say it's too much, just put a 14 bolt FF in, but that is a good price for this area. More clearance and less weight than a FF, if you don't need the extra strength. You will have to move the perches and shock mounts, but that's not too tough. I'm running the same thing in my truck. The two wheel drive model is narrower than the the 4x4 model.
