thats a thick carrier for 4.56 and up gears. will not take thick cut gears ment for 4.10 and down carriers.
but if you install a washer in each end and use a long bolt and nut to hold the locker together you can swap it to a 4.10 - down carrier.
just a bit of quick info the rest is in the link i posted.
