Is this a locker?
Hubnut
Gainesville, FL
I'm assuming it is because there are no spider gears. This came from a CUCV. M1008 I was told. Thanks
thats a thick carrier for 4.56 and up gears. will not take thick cut gears ment for 4.10 and down carriers.
but if you install a washer in each end and use a long bolt and nut to hold the locker together you can swap it to a 4.10 - down carrier.
just a bit of quick info the rest is in the link i posted.
