Big Red had a break down and after two hours got towed in by a 6cy Ford Ranger for about four miles. So just sit right back and you'll hear the tale of no good dead goes unpunished! Today is my grumpy landlord's birthday and the other day he said he was wanting some ice cream. So I thought I would be nice and do a kind jester to maybe make him feel better.
I said "red has a full tank of gas and it is only 12 miles to n fro. So off I go; I am in the Family dollar and see liquid coming from the front area and rush out side. I get the hood open and see liquid coming from the pit cock area. Yea anti-freeze; so I check the PC and it was lose. Turned it a half turn. Go back in get his ice cream and a gallon of distilled water. Added a half gallon and head out in two miles the temp is up to almost 250 and the yellow (check engine) led is on.
I get to where I can pull off and it is bubbling fan was turning top rad hose hot however no heat coming out heater and the two hoses were not even warm!
A 120 cars later and two call to the SLC and Palisades brain trust; a deputy goes by and then comes back. He helped me get the radiator cap off (I am to weak to push it for the last release). As soon as we open it water just streamed out on the LH (drivers) side. I put the other half in and got about 3/4 mile before I had to shut her down again.
So the woman who loaned me the money for the Crew Cab and her daughter saw Red and me sitting it and turned around. We hooked up my 10 foot strap (Ohhh pucker factor 10). She pulled me with their Ranger (2x4) to the switch back for my area. I fired up red and drove it on in.
So Dave and I talked and we both kind of think the water pump is not getting water through the block. Thoughts comments
I get one step ahead on the CC and now Red throws a tantrum (typical red head).
So to recap drove it 180 miles since it came back from SLC pick up. During that time we drove it off road with Mr & Mrs Campfire then parked it.
Drove it and had the issue.
Temp gauge went up
No heat coming from vents when set to (to help pull heat off)
Made bubbling noise in rad over flow bottle
Heater houses NOT even warm
Top radiator hose Hot (as in oh shiz)
Heated in about 3/4s of a mile
New water pump, new thermostat, new radiator when Cole did motor.
Temp gauge went up
