Not A Bronco submitted a new Build:
it’s Not A Bronco!
Read more about this build here...
it’s Not A Bronco!
This is my 72 blazer (as it sits today) I got when I was 19. It’s crazy looking back on it because when I bought it originally I couldn’t tell you what a distributor cap or a tie rod was. All I knew was that I wanted an old Chevy blazer View attachment 263614
It was pretty stock (looking) when it was new to me. Didn’t know it till I got it home but the rear floors are pretty damn Rusty and there’s a bit of rust on the driver side floor plan
the top was a wreck so I ditched it after a few monthsView attachment 263616
Changed the engine and transView attachment 263617
I also wanted a roof rack but didn’t want to get rid of the soft top so I built my own thing for a roof rack minus the tubing bending and welding cause I’m not that skilledView attachment 263619View attachment 263620View attachment 263621View attachment 263622
You might notice I went down to 33 inch tires rather than the 35’s that came with it, I didn’t realize it at the time but I had broken rear leaf springs and it made the suspension sag enough to where the 35s rubbed badlyView attachment 263623
Got fuel injection in late 2016 but I changed it recently, just cause it wouldn’t cooperate with me at any point and it got worse in the last couple monthsView attachment 263625After getting rid of the rear blocks and changing the front and rear spring packs I went back up to 35’s and had no rubbing afterwards, This was late last year I took this picture up on inspiration point only a few things have changed since the time of this shot
View attachment 263624Took it to a four wheel parts event and ran into kgblazerfive and Twinkie and he made me sign up here LOL. But I’m glad I did!View attachment 263626
Haven’t done much with it after that point except build a winch bumper (not finished yet).View attachment 263632And that’s about it other than changing the engine crossmember to the DIY4X cross member and ditching the fi-tech for a holley truck Avenger.
More things to come including probably a 14 bolt semi float swap. And random other things along the way
