So, Its only taken 7 years to get this truck running again. My son in the drivers seat is 11 now. When we broke one of the front Dana 44 axle shafts playing on a snow bank he was 4. That was his first and only ride in it. Its turned into the typical snowball project.
Dana 60, Corp. 14 swap, cage, boxed frame, cross over hydro assist steering, beadlock wheels, propane fuel system, 203/205 doubler, T400, electric fans, new seats, and other misc. stuff that I've forgotten in the last 7 years. Basically the motor and body are the only things I have done anything to since last it ran. I've had the money and resources just not the time.
Anyways I've got it running again with the many new modifications. Now I have to get the bugs worked out. I read the just about every thread I could find on hydro assist and it seemed like the steering was working like it should when I got it fired up. My son was able to turn it back and forth easily so I must of gotten the lines to the ram on properly. Of course I was busy dumping tyranny fluid, antifreeze and checking P.S. fluid as it was warming up. Luckily the propane idled well. We probably turned the wheels back and forth lock to lock like 3 times while running when there was a clunk noise and my son could barely turn the wheel. at the same time I noticed a puddle forming under the truck. It looks like the drip is coming from the reservoir on the pump where the hard line coming out of the back and the line might be fastened to the tank? I need to pull it apart to be sure. The pump is the stock one off a 4.3 that came with the whole serpentine set up that I added onto the motor.
All I did to it was drill the orfice out for flow and I think I stretched the spring out?
Did I maybe get carried away with these mods and something blew in the pump? ( the clunk noise?)
