thedrip
I bought a CUCV some months ago, minus an injector pump. I have a 2nd engine here, so I'm real sure I got all the injector lines in the right order, going to the correct cylinders. Pin on the pump drive lined up in the oblong hole in the drive gear. The cover was never off, so I'm assuming the drivegear could not have been moved, so everything is still in time.
All sound good? First shot at diesel stuff, I'm beginning to like it. One fiddly part (IP) the rest stick it together correctly and go.
Over the racket you should hear a "POW" as the plug is shot out
If it still won't come out attach vice grips to the loose plug and start the engine. Take a hold on the vice grips and push. What you are going for is a jackhammer affect. That will pound out the plug.
