Its that time again..*UPDATE* time ya'll. ???
Re: Its that time again..*UPDATE* time ya\'ll. ???
yeah, umm. i shot santa last year... so he wont stop by here this year..... /forums/images/graemlins/shocked.gif
no, it is going to be a WHILE till i need rims and tires. i now have a second job part time ar a wrecking yard. so i have been getting stuff A LOT faster now.
its nice.
465-203-205-D60-14bolt-5.13....
i "have" it all i just need it to get here. and i need crossover stuff and front springs. but two trucks that might come to the yard at the impound lot have 6 inch springs /forums/images/graemlins/thumb.gif
then i will be a bit farther in the process. i sent some nasty grams out today. hopefully the point will get across. otherwise i will have to make a post on it. i dont want to do that. but i will if i have to.
grant
Hmmm...
1) Rear Disc Brakes( parts arrive any day )
2) Trim Fenders More ( fronts hit a lil )
3) Continue Search for D60 (never-ending lol)
4) Recondition Power Window Units (2 Front and large rear)
K10
1. all new drivetrain (3/4 ton axles, rebuild tranny, find decent t-case)
2. 4" lift
3. finish engine (TPI/Vortec)
4. new exhaust system (new headers, 2.5" to dynomax bullets, 3" back and out the side in front of the rr tires)
5. new poly body mount bushings (tired of the truck looking like its bout to break in half)
K30
1. new starter that isn't worn out, possibly new ring gear AGAIN
2. try to get the carb to quit sticking
3. build some ramps so I can get it onto the trailer easier.
I also need to get my Scout going again and win the lottery.
</font><blockquote><font class="small">In reply to:</font><hr />
203-205-D60
[/ QUOTE ] :flip off: /forums/images/graemlins/grin.gifi dont wanna hear ya cryin on THIS shoulder /forums/images/graemlins/grin.gif
4" BDS springs (on all corners)
[/ QUOTE ]
Eric you damn wanker...How long have you had those springs and you STILL haven't gotten them installed? WFT dude? You keep tellin me your gonna come up here around Thanks Giving.....Bring your stuff and we'll get it done in a day. Homo! /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
i have a full line up of parts in my basement.
1:8 lug front 44 conversion.
2:14 bolt with disk brakes and hopefully soon my shock mounts from jeremy
3:some body parts and trim
4:build side walls with speaker boxes,install all the speakers
5:fix holes in floor.
6:fix those leaks ive been meaning to find for about 2 years.
i have many more but all in all about 2 thou in parts in my basement. /forums/images/graemlins/smile.gif
1)remove front swaybar
2)install rear shackle flip and 2" springs
3)install front and rear zero rates
4)finish rear bumper
5)get new front and rear driveshafts
6)install 14ff (finally finished disc's and shaving)
7)do something about the front ten bolt
8)find 2 more 44" tsl's and mount them on rims
9)when I do hack fenders to fit them
I think thats it. I hope!
like i said man... the stuff is "mine" but not at my house yer... ya know?
ARQ!! lemme know when ya can come out if you read this!!!
grant
Get ready for winter. Change to winter shoes on both trucks (not that the 80 sees much salt/snow), replace front crossmember with MOO unit on the 78 and fix crack in said frame, install newly rebuilt front driveshaft on 78, install plow pump, install hydraulics and plow lights on 78, replace oil pan gasket on 80 (still debating whether or not to go one piece gasket), finish interior on 80 (solidly mount dakota digital dash and tilt column), install A/C on 80, toolbox/tonneau combination from Truxedo.com on 80, install rear springs on 80, CLEAN UP ALL MY $TUFF that has accumulated and making HUGE MESS!
While all this is going on, fixing minor issues with Noangel's blazer (fixing broken body mount, replacing/fixing both power windows, installing new door lock switches, fixing/replacing dashpad, install new dash lights as several are burnt out, fixing front pinion yoke **maybe somebody has a spare 10 bolt yoke they would like to part with /forums/images/graemlins/1zhelp.gif ???**, check front end out, fix leak in oil cooler, and get an inspection sticker finally /forums/images/graemlins/blush.gif
Good luck to all those with projects (it's what keeps us young and grey haired at the same time) /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/pimp1.gif
1. 36" TSL Radials
2. Trim Fenders
3. Fab front bumper and sliders
4. Fix ball joints
5. New T case
6. Regear axles or new ones ($$$$$ dependant)
That's it for now, but it never really ends.
John
ya i forgot to add to my list cv driveline /forums/images/graemlins/smirk.gif
Ok, on daily driver 1979 K10:
Re-install 3.73 12 bolt rear to get the ratios matching again (temporarily using a 3.40 to keep it mobile).
Remove heavy camper shell
1977 C10 truck box trailer:
Re-install 3.40 12 bolt rear axle
install heavy camper shell
1966 GMC 4x4 Conversion project:
install front leaf springs
install front 8 lug 10 bolt axle
Clean, inspect and re seal 351 V6 engine
Install engine, tranny, T-case
Check, modify drivelines as required
Install body
Rewire, paint, body...
Deliver to buyer.
1960/1/2/3 GMC Jimmy project:
plan, plot and conspire, continue hoarding parts...
1954 IHC COE hauler:
Locate sleeper
install front suspension (RV solid axle w/ disc brakes)
install rear axle (Dana 70 dually)
make new dovetail stake bed...
Just finished painting yesterday! Krylon camo sand dune. It looks great.
still need to get pro-jection on.
have new center console to put in.
FINALLY got the 700r4 to shift purfectly!!!!!!!
My blazer is a sad project /forums/images/graemlins/frown.gif
1) right noe i'm swapping in Toyota Tundra tail-lights.....I swear you guys will like this when finished.
2) just bought steel for front and rear 3x7'' 1/4'' thick steel........bring it on ford!
3) new carpet front/rear $218.00 (tempe sales in az)
4)need to install my rear extended brakline
5)pwr seats out of 95 mustang there comfy, I swear
6) hook up my winch, I'll leave the oyher one at home
7) buy my 1 ton d-shaft from jesse......hello mastercard.
8) Install my roll bar, soft-top,tube doors, new push rods and arms, paint it, wire the lights, install my new 4.56 gears and find a darn locker, used/cheap.
much do do and alot to screw......up that is open to parts or ideas, I also said it would be done in june, then by Blazer Bash,then by start of school, now by Jan.
18 month project so far!!!!!!!!!! /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
