KansasTwister
well, since i want to make my k5 a daily driver, ive been tossing around the idea of a more modern drivetrain. Not too long ago i learned the 4l60e would swap the 700r4 perfectly, and i had already known the potentials of the 5.3 genIII motors, as i learned more about them i wanted one more and more. For the last five years the k5s had no motor and not moved under its own power.
The motor itself is from a 2004 silverado, 60k miles complete takeout (Accesories and computer). 600 (i got a screaming deal).
http://cgi.ebay.com/ebaymotors/ws/e...akeTrack=true&ssPageName=VIP:watchlink:top:en
Ill be using the above motor mount adapter plates (Already got a pair in my buddys 67 c10 that worked flawlessly when we dropped a 27k mile 5.3 in)
I still havent picked out the trans, but it will be from a similar year 4l60e 4wd.
Eventually id like to swap for a np241 t case (89 mechanical speeedo to save form having to change cluster out). Summit used to carry the vss adapters, i believe i found the same thing on jegs. (summit had the option for tbi or ls1 style motors, but this one doesnt say how many beats per mile it is)
http://www.jegs.com/i/Caspers+Electronics/182/102049/10002/-1
Fuel system, im planning on using a 87-91 blazer tank with a newer fuel pump (if im correct, this will allow me to use stock gauge still). For regulator, im going to use vette style dual in one out mounted at rear of vehicle and just run a single line forwards. (not sure what all fitting or adapters ill need for this)
Ill probably keep the thorttle by wire setup, since its not hard to install the pedal in my 86, but would be a pain to try to switch it to cable style.
Airconditioning can be worried about later, although ive seen a third gen guy using stock style ac compressor via custom bracketry. And i dont believe i should have any problem with the genIII truck accesories or oil pan correct?
http://www.thirdgen.org/techboard/ltx-lsx/487936-ls1-700r4-swap-into.html
For the harness, theres a local guy who simplifies and extends and reprograms for your vehicle the wiring harness, $400
I know im going to need other things like hoses, possibilty a radiator, lots of patience when wiring, im going to put new brake pads shoes and hoses (since my k5s been sitting on grass for 5 years now without a motor).
Some of the concerns i have are gonna be my 32s and 3.08 gears (id prefer 3.73s). Will this make overdrive useless?
Any thoughts or opinions you guys have let em rip, im all ears. Im new to this tech, so if theres a better way im missing fill me in. I dont think the 5.3/4l60e/np208 will be a bad daily driver/commuter combo, i know its not gonna get the same gas milegae as a honda, but should be better than my old 350 quadrajet and 3.55 non overdrive 77 pickemup. Ive probably missed covering some things, but i think ive got the big issues covered.
