superkingd
Newbie
kind of related but I BELIEVE top fuel dragsters use no head gasket, No water to worry about either. But I could be wrong
Wrong. Not only do they use a head gasket, it's part of their tune up. They use a thicker/thinner one to raise/lower compression ratio depending on conditions.
its not in my sig anymore is thats what your going by. its a 24v ISB head and engine. Ive seen the MLS gaskets work really well on 3rd gens (stock mls gasket) and take alot of abuse. but not so much on the older ones.
...... you guys doin it up..... guess when I built my little 350 small block I didn't know what I was getting into with the mls gaskets.... guess a bling squirrel can find a nut every once in a while..... cool huh
They don't use a one piece head gasket but they do use compression seals for the liners and the liners have a very close tolerance for below the deck, and they use shims on the deck at the front and rear to keep the head from deflecting. I think that I've built a few hunderd 92s.
Gus
much like this 'eh...........this was my point. theres no "head gasket" fire rings, perimeter seal, 2 shims, and 13 orings......... not exactly a "head gasket" this is effectively what oringing a head with stainless wire nets you. a virtually positive seal at the fire ring. and the rest of the HG just to fill space and keep water and oil from running buckwild.
