Took a wire wheel to the tubes and pumpkin, still need to pull the knuckles off and clean them up good and paint them
How it sits now, driver side rocker is on its way out, roof has some surface rust, the floor in the back is the same as when I cut out the rust the rhino lined it.
Wfo crossover, was gonna do high steer but I'm worried about clearances with how little lift I plan on running
Where I had to put a new fuel pump in, but I've got the replacement panels for the back already, cost me $50 for both brand new.
Vortec roller cam, air clearer, headers and gaskets
Well got everything for cross over, scored some scratched Yukon hardcore hubs for $200 shipped, started cleaning up the 60, closing on my house at the end of June. Went ahead and put it on some 17s so I don't have to grind the front calipers on the 60. Had a little trouble getting the lower kingpin cap off, but I just ordered my king pin rebuild kits. Did get it back up running and driving put a drive shaft in it and drove it around the parking lot. It's been 10 years since I did that so I was happier than a pig in shit.
After I close on the house I'll do the 52/56 spring swaps, swap in the 60, do the crossover steering get me a front driveshaft and then get the tires. Still haven't decided on tires but 42-44s are what's gonna go on it. Just want to drive it around town then I'll put 35 spline chromos, lockers, and the roller cam swap. Then later on I'll do the doubler, flat belly, and the cage.
When building my jeep I decided that stages but keeping it driveable is key to enjoying it, not long extended periods of it being tore down. You lose interest when you do that.
