J-code intake, 6.2
herkdriver007
OFallon, IL
Hey fellas, I'm looking for an intake... Please post up if you have a j code intake you're looking to get rid of. I'm located in central AR. Needs to be in decent shape... Thanks!!
I have one.
$40 plus shipping
Make sure it's the right plane, single or double, for your truck.
There are different planes? Thought the only differerences were the air cleaner studs, north/south vs east/west...??
Single plane should have one plenum and one CDR valve fitting. Dual plane should have two planes and two CDR fittings. There's differences beyond that through the years but so long as you have the same plane and the right stud setup you're fine.
I have both, I will check shipping.
