I have a feeling the rear toe link adjusters have come loose on my DD.
Under hard acceleration from 70-110mph, the car is super squirrelly, which usually means a toe problem. I just had some aftermarket toe-link adjusters installed, so my suspicion is that they have vibrated loose already...
I was going to get the rear toe checked and then use either Loc-Tite Blue (applied to threads before threading the jam nuts all the way down) or their Green which is more of a "wicking" product designed to seep into the threads after everything is completely tight. I will occasionally need to readjust these links so I don't want something TOO aggressive, and the Green appears to need heat to break it loose later on. Is Blue the right product?
The link material is 6061-T6 aluminum if that matters...
-G
-G
stuff is sick...
But they disassemble easy also.
Actually a little grit and rust hold them in place well. Okay enough talking about sleds I think it is still summer but it has'nt felt like it around here lately. Stupid Rain!
