spencer13
Registered Member
Hey all my name is Spencer and I've got a...
78 Jimmy
4" Rough Country kit
-Front Springs
-Rear Blocks
-Extended Brake hoses
-Sway bar Drop
-Raised pitman arm
-Dropped Transfer case about 1.5"
33s
Front 10 bolt
-warn locking hubs
Rear 12 bolt
NP203
-Part time kit
I want to go up to 8", or maybe 8" front 6" rear because I like that sorta stance. This is what I'm thinking,
Front 8" springs
Pitman arm spacer (between arm and axle)
-Superlift
Front cv joint- machine for clearance
Rear Shackle Flip +4"
Rear block Either 4", 3", or 2" I'll play around to see what stance I like
Extended Rear Drive shaft
Main questions are rear drive shaft angles, what degree is your tail shaft at and how much did you drop your T case?
How close did you get your axle yoke angle to that?
Would extending the stock on cut it?
If not what shaft and joints should I get?
and Superlift also has a z drag link, good or bad?
Any help would be great, and tell me what you think of my plan, anything I left out, ect.
78 Jimmy
-Front Springs
-Rear Blocks
-Sway bar Drop
-Raised pitman arm
33s
Front 10 bolt
-warn locking hubs
Rear 12 bolt
NP203
-Part time kit
Front 8" springs
-Superlift
