Why don't you stick to worrying about your own posts Tim...
A tweak to gain a little more room at the collector isn't a fitment problem in the sense it was being discussed. Bolt access and plug access and wire burning are issues that are much more difficult to fix and are the ones people bitch about. If Dorian didn't have problems there then I'd consider his set to have fit perfectly. As he pointed out, the shackle didn't hit his headers, he just wanted a little more clearance down there. BFD.
Rene
I had thought he'd done more than, "tweak" his $400 headers. Before I posted that, I had thought he had to actually heat and bend his headers with a torch to make them fit correctly.
Asking the question added clarity in my mind, and added something to the thread if you ask me. If someone says that they fit perfectly, they should bolt on with zero issues and clear everything.
If you've got to "tweak" them a bit, it might be minor, but that is not fitting, "perfectly".
I didn't think my comment was out of line at all, you just take it that way.
