K k5blayzer Registered Member Joined Sep 29, 2005 Posts 68 Reaction score 0 Location oregon Sep 21, 2010 #21 AC and cruise controll are tapped off of there.. neither of which i use.. if i unplug the one for the AC will my heat still work?
Muddytazz 1 ton status Joined Jun 30, 2002 Posts 20,072 Reaction score 2 Location Salem, Or. Sep 21, 2010 #22 I believe so since the whole system is a HVAC system. If you don't use your CC just unplug that and tap that.
K k5blayzer Registered Member Joined Sep 29, 2005 Posts 68 Reaction score 0 Location oregon Sep 21, 2010 #23 somethingabout 42"s and cruise control just sounds scary..
K k5blayzer Registered Member Joined Sep 29, 2005 Posts 68 Reaction score 0 Location oregon Sep 21, 2010 #24 problem is solved.. it shifts nice and hard, but im starting to re think the decision to install everything with a high stall toque converter..
4X4HIGH 1 ton status GMOTM Winner Joined Dec 14, 2001 Posts 22,423 Reaction score 662 Location Fremont, CA. Sep 21, 2010 #25 k5blayzer said: problem is solved.. it shifts nice and hard, but im starting to re think the decision to install everything with a high stall toque converter.. Click to expand... High stall convertors belong in hot rods and race cars, not a 6000 lb. truck for low speed use (defeats the purpose of the use of your rig).
K k5blayzer Registered Member Joined Sep 29, 2005 Posts 68 Reaction score 0 Location oregon Sep 21, 2010 #26 guess i should a thought about this before install... i guess i need to trade someone off..
