With the bolt issue out of the way I figured I'd spend today going through stuff and addressing the door. We're going wheeling next weekend and I wanted it to be ready to roll so I didn't have to mess with stuff too much during the week.
Got the door open!
It DESTROYED the shape of the cab and the door itself was really tweaked. So after a lot of hammering, relief cutting, welding and grinding I got everything squared back up... and ya' know what? It actually fits pretty good!
It broke the latch and bent it all up so I had to run down to pick-n-pull and grab a new one. $17 well spent vs straightening and welding up the breaks in the old latch. So everything opens/closes again and the latch works. I'm good with that, everything else is just cosmetic.
Checked the u-bolts, steering arm studs/nuts, lug nuts, suspension bolts and anything else I could get my hands on. U-bolts were a tad loose but otherwise everything was tight.
I checked the steering linkage and both jam nuts were loose on my draglink but I noticed some scratches on the passenger side so I think it's taking a beating from the top of my passenger leaf spring pack. I'll need to address that eventually. When I was tightening those up I noticed it looked like a bit of play between the sector shaft and pitman arm. Not much, almost missed it but if you grabbed it you could wiggle it ever so slightly so I pulled the nut off and it looks like the nut was bottoming out on the threads just exactly when it was coming in contact with the face of the pitman arm.
So I grabbed a lock washer and put it in between so the nut would bottom out. Problem solved and it tightened it up. I guess when everything was so new it was crazy tight on the splines and I didn't notice.
Fired it up and took it for a drive, drove nice as usual so I rolled it back in the driveway and gave it the stamp of approval to go beat on it next weekend.
