K10 gets an ass transplant
Larry
Largarto Rancher & Tumbleweed Farmer
Author
A windy corner of a dirty street: Pueblo West, CO
As many of you have read, I’ve been chasing an odd issue with my 10.5 14 bolt in the K10 for the past few years where it likes to purge oil after a few hours of driving on the Interstate at 75 to 85 MPH. When driven on state highways at slower speeds or off-road there has been no issues with oil purge…only at high speeds. About a year ago, I ripped it down and inspected and replaced every bearing, race, seal, and verified and driveline angles and back lash. There was no smoking gun, no signs of overheat and only found one bearing (wheel bearing) that had a loose cage. Hardly a culprit.
We took off on Desert Trip 2016 and sure enough, a few hours of Interstate driving it started belching oil again. I had a cheap Hazard Freight inferred thermometer with me where the rear diff covers between the K10 and Suburban were within a few degrees of each other (the rear axles in the K10 and Polar Bear Suburban are identical, minus the fact the Burb has an open diff). Again, proving that it is not an overheat issue in the K10. The popular opinion is there is nothing wrong with the axle at all, just a stack up of tolerances between the 4:56 thick gears, Detroit locker, heavy truck, tall tires and high road speed.
The answer would be to slow the hell down on the Interstate, which I am not going to do. I want to be able to keep up with traffic and even pass traffic but without using my James Bond oil hose squirting everybody as I pass them. Being I am sick and tired of the Detroit Locker antics of click bang!, the truck darting one direction under heavy throttle then darting the other direction when letting off I decided it was time for a selectable locker. I also wanted to go to a little wider axle housing to even up the track so I followed Mosesburbs recipe with a 70” wide (hub to hub) G-Van axle to more even up the track to the front Dana 60 at 69” wide. As a comparison to the 67” side C20 axle I’ve had in it for 20 years.
With that, a fresh rear is in process for the K10….
Hopefully, the ass wiping when the purge bottle over flows will be over now. Talk about a sticky mess all over the back of the camper and trasheroo.
This is the axle donor. A very nice and clean 1995 G-30. Not even sure why it was in the salvage yard. Originally a BBC/4L80E van too
After some power washing, which it didn’t need much as it was so clean already
The tear down began. It had a G80 4:10 carrier still up for grabs in the Classified section
After a quick call to the nice guys at ORD a new ARB RB114, ring gear bolt set, spring perches and 4:56 gear set appeared. My buddy Bill has a lot more experience with gear set ups than I so he did the fine tuning. Like a dog, I have to keep food in front of him so he can keep his eyes on the prize. See if you can find the hidden Oreo cookie. Oh, and cutting off those old spring perches were the two worst days of my life!
Truck porn!
The Quality Control team said it passed inspection
As many of you also know, I am not a fan of rear disk brake conversions. I don’t have a problem with factory rear disk axles like 2001 and later GM HD trucks but still not enough to go buy one of those axles for this swap. That said, I had to change the backing plates as the G-van axle had the later pushin type brake cables whereas my K10 requires the bolt in for easier hook up to the original brake cable set up.
The first order was to rip the backing plates off my old axle and sand blast them then weld up the shoe wear marks in the backing plates. I’ve come to notice trucks (usually manual trans rigs) have major wear marks in the backing plates whereas automatic rigs do not (the G-van's backing plates were perfect). I recently welded up the wear marks on the Polar Bear Suburban’s backing plates and found a HUGE difference in park brake performance once the shoes weren't being forced to dig into the backing plates anymore. It holds like it is drilled into the ground now. Fixing the K10’s backing plates should make a noticeable difference as well. The park brake hasn't been working as well as it used to.
Weld’er up!
After
Another thing I experimented with on the Polar Bear Burb a while ago when doing its brake job, was moving to the larger DRW wheel cylinders with the larger 1 3/16 bore (Napa 37337). The SRW wheel cylinder has a 1 1/16 bore (Napa 37290). Moving to the larger wheel cylinders also made a noticeable difference in how the Burb stops however, I wouldn’t recommend the large wheel cylinders on a lighter Blazer or truck as the rear brakes can become pretty aggressive. The DRW cylinder is on the right.
Treated the backing plates to some fresh shoes, park brake cables and cleaned up hardware. All the hardware was just replaced about a year ago
And this is how she sits at the moment until I get some work travel out of the way.
Next up will be some frame clean up, cutting off some old exhaust brackets that are easy to get to with the axle out of the way then roll the axle under the truck to set up the pinion angle and burn in the spring perches. After that, comes the new shock layout and ARB compressor mounting. That’s it for now….
And don't forget, the old axle is still up for grabs in the Classified Section as well. Great axle, just don't drive 75+ MPH for hours on end in a 8,000 lb truck :haha:
Some dude from CL is supposed to be picking it up Friday when I get back from CA but you know how CL peeps are :thinking:
that jack.... :pimp:
Man, that jack and the Landa hot water pressure washer are the two handiest tools I have. Both are left overs from my dad’s shop. There was a matching Gray scissor jack for semi’s that went with it but it was way too big for home use and sold it years ago. The bumper jack I have needs a new tube as it won’t hold its spot for more than a few minutes and must be lowered on onto the safety stops right away. Between this one and the scissor jack, I’ve almost killed myself a few times over the years but would still have them over a 2 post lift any day.
Bring me that van...
Dude, that van is clllleean! A Pueblo native van sold at Spradley Chevrolet here in town. Engine, trans and now rear axle is gone. I grabbed some hydrobooster bits off of it while I was there too. Would have loved to had the whole thing for a project but with the powertain missing it is too far gone. Great for body parts now though
I want to eat off of it.... haha.
Cool thread. Weird issue with the oil stuff....
I was hoping to take pics of you wiping the K10's ass with toilet paper on the desert trip this year! Killjoy!
All kidding aside I'm curious to see how the truck handles on and off road with the wider track outback. Plus none of the herky jerky motions on the highway on/off throttle. Can't wait to see it get stuffed in. Good work dude!
years ago I had a 4l80-e that would get warm and purge fluid for no reason out the vent .
I hooked it to a bottle and would dump it back in from time to time.
1 day she pegged out the temp gauge and I figured I was done . . . . . she never over heated again like she had been doing or even purge again . . . :dunno: who knows what it was inside that finally let go and un plug its self.
I'd love to find a van like that donor..never have seen one with a BBC factory,I know they "listed" them in parts catalogs,never saw one in person though...that thing was set up pretty beefy,with a 4L80E and BBC,and that rear axle...
One question --on your e-brake cables that "bolt on" to the backing plate,there are two metal plates on the cable the bolts go through--my '82 GMC needed new cables last spring to pass inspection,and in my haste to get it apart,I just torched the bolts off--then didn't think to look to see how those plates were arranged--on the other side ,the plates were sandwiched between the backing plate--one outside,one on the inside...I "think" the other side had both plates on the cable on the outside of the backing plate..
Not sure if it matters much,I just put the new cables on in the same manner the old ones were--the side I put one plate inside and one outside,doesn't seem to work as freely as the other one with both plates on the outside..but as long as its working--I'm not taking it back apart again unless I have too...it was not a fun job ,and the new cables ended up being about 1-1/2" too short,had to fudge a hunk of threaded rod onto the intermediate cable and leave it off one of the wire frame guides,in order to get them to work..
The 4l80e in my old 91 did this also. Fluid never looked burnt but it would sporadically DUMP fluid out of the vent. Rebuild stopped it but the shop never saw a red flag.
There was another thread somewhere I read about a 14B burping gear oil like yours on the highway. IIRC he setup an overflow tank so it would burb into the tank when needed and then flow back into the axle when he slowed down.
Just curious if you ever put the vent cap on the line that comes on factory differentials or did the oil spewing shoot it out?
