K20 rear driveline
Muddytazz
1 ton status
Salem, Or.
On a K20 rear driveline, is both the 14FF yoke end and the 203 yoke end the same u-joint? The PO of my dads burb flipped the driveline putting the slip sleeve down by the 14FF and it vibrates like hell on deceleration(worn out). What I'm trying to figure out is if the PO just flipped it or did he replace part of it? Anyone have any imput?
All the stock GM stuff that I've worked on had the same size u-joints at each end of the rear shaft. /forums/images/graemlins/cool.gif
The K20 that I got my axles from had a 203 and both u- joints were the same size. When I got it the slip yoke thingy was on the t-case end of the shaft.For what its worth, it wasn't stock, the PO had definitely "tinkered" with it.
77 k20 had two sizes, alot of full time 70s k20 were like thios, there was a thread about this not too long ago, i have one right nowq thats 77 k20 and its got small joints for case and large for axle
it is common and normal
