Current projects are the bed winch and the air system. Now that the bed winch is mounted all that's left for it is to move it's solenoid box up on top of the service bed where it will be accessible without climbing into the bed. Left the crimper in my other tool box so can't start on that until monday. Which leaves the air system.
Air system will be used for tires, tools, and the planned air suspension (helper bags) for the truck and trailer. Was going to use the big air tank but since it has a hole in it going to use the smaller air tanks from a military surplus truck. 3 tanks. Have 3 air compressors available to use:
1. Viar 88p electric
2. Engine driven compressor from the old m35a2. Small dual piston, somewhere around 8cfm rating with it's stock large pulley.
3. Large engine driven compressor that came with the bed. 4 piston.
Current plan is 2 compressors. The little 88p and the large 4 piston compressor that will be driven off of the hydraulic PTO. Little 88p can handle the suspension adjustments and anytime I need more will just kick on the PTO to power up the big compressor. The big guy will probably end up inside one of the rear boxes on the service bed since that will protect it, and still fits even after the bed gets cut.
88p will most likely get mounted inside of the front passenger side box.
The 3 air tanks are going at the front of the bed along the inside edge of the driver side front box. Mounts are pretty simple with some angle iron and large U bolts. When the remaining fittings come in the rest of the tanks will be plumbed.
