trevmountain
I am in the process of swapping over a standard OEM tailgate to take the place of my damaged K30 tailgate with the lights.
I looked all over to try and find a tailgate from a K30 so I wouldn't have to do this but no luck. I've got an absolute perfect OEM gate and I want to just hole saw the holes transfer over the wiring ect. After looking at it last night it appears the light strip on the inside slides in from the side where the latch bracket is. So basically I just need to figure out how to get the latch temporarily out of the way so I can remove and slide in the strip from gate to gate. Its going to be a pain in the ass because I will also need to fish the wire out the bottom for the power source. If I remove the screws that secure the handle does the whole latch system just kind of split and I'll be able to pull the piece out of my way, and also if I disconnect am I going to be able to put the latch system back together?
If anybody has messed with these old gates before and can give me some tips before I start into something that may not be possible without splitting the tailgate open.
Here are some pics of what Im talking about
