Russellk30
I found a junkyard 2wd Chevy steering gear for $20. Stripped and painted it. Bought a threaded end cap and tapped the top cover. The front half of the frame was wire wheeled and coated with Por15. It paints a lot smoother and covers more area when thinned a little too. FYI, Por15 works only on rusty or treated metal. It peels like skin off a sunburn from shiny metal.
B52 brackets were painted and installed. I'm running stock 56" springs on all four corners. Picked up a set of springs for $26. Cant beat that. All the bushings are the same size. The engine mounts bushing will be the same size. I'm also thinking about fabbing up a transmission crossmember with sleeves for the same bushings. I want as many parts standardized as possible.
The Dana 60 is all stripped & trimmed. I'm waiting for a 7/8 allen wrench to come in the mail to remove the old kingpins. $20 off Amazon. They are gnarled up pretty good. No wonder I was getting a little death wobble. Has anybody every actually died from death wobble?
