K5 blower motor question
77k5blz
Mchenry illinois
I bought a 77 k5 a while in need of work there wasnt a blower in the housing I just put one in and as soon as I turn the key on it blows on low even with the selector for vent def heat etc... Off. Is this normal or do I have a problem thank you ahead of time.
I'd say swap in a later heater control head, I believe they interchange, and I think that is how that setup was run, with the lower position on the early switch still sending power to one of the resistors on the fan housing.
I suppose you could just kill the lower heater position on the switch too, but that might get annoying. The later heavy duty and AC control heads I *believe* had one more switch position, the bottom-most being an actual off position.
Most all 73-87 GM trucks had the heater blower wired as such to be on "low" speed even with the switch in the off position...as Dorian stated,their "Flo-Thru Ventilation" package with the vents in the doors worked in conjunction with the blower motor to provide constant fresh air into the cab without an annoying breeze (supposedly)....................................................................................................................................................................................................I found it irritating to have the blower come on instanly on an icy winter morning,and blow a frigid breeze on me,and it also would "scream" sometimes and scare me silly,thinking a bearing seized up in my engine!........so...a few minutes with my test lamp isolated the low speed power wire on the blower motor resistor on the firewall,and one quick *snip* of the side cutters silenced the squeaky screamy blower motor until I turned it on to medium or high speed,like it should have been "factory"...if you still want low speed you could snip the wire for low speed and put a toggle switch in line with it to "kill" low speed when desired...
Just for clarification, are you sure any of the later ones (1981-ish?) were wired that way? My setup is the HD heater, so it's different anyways, but I thought that on all the later heater setups (HD Heater, AC, and standard) the bottom position of the fan speed switch was "off"?
My '82 K2500 stayed on low speed constantly with the switch off,so did my 77 GMC and 79 C10 Bonnanza I had...I'm pretty sure my 85 Suburban doesn't run the blower on low though,when its "off", its OFF--that has factory A/C,none of my other trucks did,so I bet ones with A/C or a HD heater might be wired differently................................................................................................my 81 G10 van has no A/C ,but I dont recall the blower being on low speed in the off position ,strangely enough,because the wiring harness in it is darn near identical to a pickup,even the same color codes...it does have a "hi output" heater core however,it had a straight six originally and the heater would drive you out if you left it on hi for long--I think my Burb has the high output heater core also...it too feels like it could heat a home!..
