I need to know what to do with these two lines. In the first image the part sitting on the fuel rail toward the front of the engine should have a wire connection going to it and a hard line coming off the back. The wire connection is not on the engine harness from PSI harness and I do not see anywhere that the hard line should go to at the back of the engine.
The second picture, I believe the circled line should go to the air intake after the sensor but I do not have a port since I put an aftermarket cold air intake on.
I read a couple articles where the line is the second pic was removed and a small filter installed. Either way, I do not know if I need these items or how to go about eliminating them. Any help would be appreciated...
