I can't find one anywhere local. Who has one they want to get rid of?
85 and 86 share identical plates.I would be interested in a skid plate for a "W" cross member with 208 case. Not sure if that is the same plate as the "S" shaped cross member or not. The driveshaft side looks similar enough.![]()
87 up to 91 are all interchangeable.
Even though the 85 to 91 have similar shaped 'members there is a slight variation between the two that allows their specific 'plate to fasten to them. As I've stated many times with people looking for a 'plate, post up a pic of your crossmember just to make sure you get the correct skidplate.
You have a double hump or 'W' crossmember and need a skid plate from any factory civilian 85-86 or 87-89 carbureted one ton. No CUCV.
