No problem man, wish it woulda worked for you. If anyone needs it lmk.
I have the factory skid plate off of an 85 blazer. Also have the crossmember. It is the W crossmember I believe. Would it work for you?Ok, the straight-line hole pattern on the W-cross member is about 7" between holes. Significantly narrower than what you have. Mods are always possible, but this would not be a bolt-on part for me.
That's consistent with what @thatK30guy and @GonicGM were saying earlier. Thanks for checking.
Ill message you.It surely should! What would you want for just the skid plate? I already have the cross member.
