k5 problem
michaelgilitiuk
arizona
I have a 81 k5 with a 95 tbi 350 im having problems with it taking off its real slugish.I changed the fuel pump and plugs because the plugs were due.i changed the 02 sensor also it helped alot but diddent fix it.i checked the knock sensor its good i checked the tps its good the coil is good also.I forgot to say i have a exhaust leak on my header on number 8 cylinder.i also have a msd box that i put on a year ago.its sluggish when i take off then goes away when i get on it then it will get sluggish its real sluggish when i take off . ext ext please help
Have you scanned for codes yet?
This is what I was going to say.
You could have a clogged catalytic converter or blocked exhaust. Your fuel injectors may be shot, or your fuel pressure regulator may be shot. Search on my username for TBI and you'll see a lot of troubleshooting steps I've posted for other TBI owners.
But first, CHECK THE CODES. :)
ya its saying its lean and my fuel pressure was low so i put a new fuel pump in it and fuel filter now my fuel pressure is good it helped but diddent fix it i need to take the battery cables off and check the codes again
Did that fix it?
If not, did you check the fuel pressure? Your fuel pump does not regulate the pressure, the fuel pressure regulator does. If you have problem still, check the FPR.
Did that fix it?
ill do that tonight i just dont want to change parts that i dont need
Did that fix it?
ya i checked it before the fuel filter the fuel pump was bad so i put a new fuel pump in it then checked it again and it was good at 15 psi
