The K5 has the saggy butt syndrome. Not so apparent now but I figure once the heavy ass front bumper and winch are gone it will be more noticeable.
I honestly like how it rides. I figure after the new shocks are in it should firm up the bouncing and swaying as the ones on it aren't doing much now. I don't want to end up with a harsh, hard ride but I'm also kind of wondering about axle wrap, especially if I add a zero rate to it.
I put a BDS long add a leaf in the stock pack of my Ranger to help with a nose up attitude it had. Stiffened up the rear a bit but definitely wasn't as bad as I hear people talk about short add a leaves. Got 1-1.5" of lift out of it and it acted more like another leaf in the pack than another overload.
I've also used zero rates in various vehicles.
Zero rate - cheap, easy to do, effective one inch rear lift. Might add to axle wrap issues that may or may not exist.
Long add a leaf - not as cheap (still not expensive though), help stiffen up the pack without being harsh like a short add a leaf...but will it be worth the extra effort?
People still do that? Good way to make a saggy spring a stiff riding spring that quickly sags back to the way it was or just worse than it was.
), zero rate if you don't want it stiffer. Pretty simple question i think.
