1''x2'' tubing as a base 1/2 emt hoops the front channel over the windshield [from a jeep] you'll have to customize that.
I did'nt use snaps on the bed sides.. don't like them.
But I did use them on each side of the wind shield
Make some straps in the back to go around your center hoop to pull tension on the whole top. The back window is velcroed to the tailgate.
All windows have zippers on each side.
Mine is a full top so I used full doors as a window frame.
They are not water-titebut, they keep most of the rain and wind off.
pipe insulation on the 1/2emt around the door helps that.
I did a few drawings and took them to an Awning/ boat cover shop who under stood what I was after and they made the whole thing for $460.00
That was over 4 years ago[your prices may vary
] Even if youmade your own hardware and went to an auto interior shop, you willhave what you want for a lot cheaper
Any questions P.M. me.
